Can't get camera to match between projects
I’m rendering a few passes on a model and the way I used to do it is, find the right camera angle in one project and type in the values of the camera (distance, azimuth etc) into my other projects. They used to match perfectly and I render them out to composite in photoshop.
I’ve run into a problem where even the values are the same between my files…the model is placed ever so slightly off. Instead of matching exactly. What am I doing wrong?
Is there a way to save a camera and import within keyshot?
I’m using keyshot 11.
You have to match not only the camera location but also the camera target. You can use a trick by placing the invisible object in the centers of your models and targeting the camera at it.
